Activity Forums Adobe After Effects Make video more jitterish
  • Make video more jitterish
    Posted by David Garcia on February 22, 2014 at 7:57 pm
    I want to create a different look to my film. Like this one?
    https://vimeo.com/32999037
    Any idea how he does it? High shutter speed and then slowed down?
    It seems almost as if frames are skipped.
    Any help would be helpful
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    David Garcia replied 12 years, 7 months ago 2 Members · 2 Replies
  • Todd Kopriva
    February 23, 2014 at 4:00 pm
    Create a composition with a low frame rate. Nest the composition containing your footage layers in this lower-frame-rate composition.
    Or, you can use the Posterize Time effect, which is a bit simpler but a lower-performance method.
    Details here:
    https://helpx.adobe.com/after-effects/using/time-effects.html#posterize_time_effect
    After Effects team blog
  • David Garcia
    February 23, 2014 at 4:07 pm
    Thanks a lot.
    It sounds like it is what Im after. Will try it!
