Activity Forums Adobe After Effects Make text layer not to accept lights
  • Make text layer not to accept lights
    Posted by Robert Hoisan on February 16, 2011 at 1:41 am
    Hey!
    I have a text layer, precomposed, 3D enabled. All other layers are 3D in the main comp and i have one ambient light. If i turn off “accept light” for my comp (with the text layer inside) it still accepts light. If i enable collapse transformation it stops accepting light but the text looks real fuzzy.
    What could be the problem? I need my text not to interfere with the light…
    Robert Hoisan
    Motion Graphics Artist
    Gilles Gagnon replied 14 years, 10 months ago 4 Members · 7 Replies
  • 7 Replies
  • Robert Hoisan
    February 16, 2011 at 10:58 am
    I got it, never mind the post. I had 3D per character enabled for my text inside my 3D comp so i disable it and it’s fine.
    Robert Hoisan
  • Michael Szalapski
    February 16, 2011 at 1:59 pm
    Is your text layer 3d inside the comp that contains it? If not, make it so and turn off accept lights on it.
    – The Great Szalam
    (The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)
  • Tudor “ted” jelescu
    February 16, 2011 at 3:52 pm
    I tried replicating the problem but it worked for me- 2d layer text, 3d precomp, turn accept lights off and it works just fine.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Gilles Gagnon
    October 31, 2011 at 9:21 pm
    Hi all,
    this may be a dumb question but where do you find the “accept lights” switch for the text layer?
    CHeers,
    Gilles
  • Michael Szalapski
    October 31, 2011 at 11:39 pm
    Same place as on every other layer. I believe the shortcut is to press AA to reveal the layer’s 3d options. Check the help, if I’m wrong.
    – The Great Szalam
  • Gilles Gagnon
    October 31, 2011 at 11:54 pm
    Thanks…
    however my layer is 2D. It appears to be affected by light. Unless I’m wrong and it’s another setting that is making the color uneven on the colored text.
    Gilles
  • Gilles Gagnon
    November 1, 2011 at 2:15 am
    Nevermind…:)
    I discovered a pesky effect on the layer that was causing the “uneven” text color. I removed it and voila! just as I wanted it.
    Thanks again!
    Gilles
