Activity Forums Maxon Cinema 4D Make Sweeping Connection Between 2 Objects + Animated See Through Object
  • Make Sweeping Connection Between 2 Objects + Animated See Through Object
    Posted by Grant Strac on January 9, 2014 at 3:12 pm
    Two things.
    1) I made a cylinder, and spline/extruded rectangle with a taper off at the end. I want to connect the top (non tapered) part of the extruded spline rectangle to the cylinder to match the object I am trying to make. It’s a swooping connection to make it a smooth model to the rectangle.
    2) I want to cut the cylinder in half and show the internal components working. I normally would animate a slice but is there a way to make something similar to the x-ray option? I found a post saying apply a transparency to a select group of polygons but I want to animate the item working and then cut in half to see inside.
    I attached pictures to help visualize what I am trying to do. Thanks in advanced for helping.
    6979_photocopycopy.jpg.zip
    Grant Strac
    Grant Strac replied 12 years, 8 months ago 1 Member · 0 Replies
  • 0 Replies
