Activity Forums VEGAS Pro Make subtitles “pop”
  • Make subtitles “pop”
    Posted by Pat Bailey on May 9, 2011 at 11:46 am
    I have written the words under the pictures.
    I want people to be able to easily read the words so they can sing along.
    How do I make the words “pop” in sony vegas pro 8.
    I have already written the text to go under each picture. So I want to do an “en bloc” change.
    Thank you
    Pesha
    Pat Bailey replied 15 years, 4 months ago 2 Members · 2 Replies
  • Stephen Mann
    May 9, 2011 at 5:02 pm
    It’s been so long since I used V8, I don’t know if my solution will work for you.
    Import the text as a Photoshop PSD file with each word on a separate layer. (Import across tracks). Listen to the music and drop a market at the start of each word. Between each marker you wil one word. Animate the word (each word is on a separate track) to zoom into it a little (the “pop”). (You can ctrl-c copy the keyframe parameter of the zoom-in to make it consistent).
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Pat Bailey
    May 13, 2011 at 7:36 pm
    Hi Stephen Thank you very much for your help.
    I expect this will make a very good difference. I will try your solution.
    Best wishes
    Pesha
