Activity › Forums › Adobe Premiere Pro › Make Still Frame Without Export
Posted by Preston Orrick on July 12, 2012 at 3:21 pmHow do I make a still frame to keep within my project without exporting? I’ve seen Frame Hold, but it doesn’t hold at my current position.
Preston Orrick replied 14 years, 1 month ago 6 Members · 7 Replies -
Vince Becquiot
July 12, 2012 at 5:58 pmHi Preston,
While you could use remapping, frame hold is the easiest way. But it doesn’t work like After Effects.
Make a cut where you want the still fame, set to hold at in point and set your out point.
Vince Becquiot
Indigo Live
San Francisco – Bay Area -
Ann Bens
July 12, 2012 at 7:53 pmIf your clip does not have enough frames to make the required duration or you want to use the last frame of a clip, use the stretch tool to stretch to the required length.
Adobe Certified Expert Premiere Pro
Adobe Community Professional -
Preston Orrick
July 13, 2012 at 3:05 pmOkay, thanks for the advice. Adobe should really have something easier in place. FCP6 is very easy for making a still frame.
Dustin Parsons
July 13, 2012 at 5:44 pm[Preston Orrick] “Adobe should really have something easier in place. FCP6 is very easy for making a still frame.”
Agreed, a simple “Make Freeze Frame” option would be much more convenient. Adobe Feature Request
Bill Walkman
July 17, 2012 at 12:11 amIn CS6 there is a camera icon in the controls on the top left hand clip window — “export frame”.
Preston Orrick
July 17, 2012 at 1:49 pmUsing 5.5 at the moment, but will be sure to take a look when I upgrade.
