Activity Forums Adobe Illustrator Make scaleable template
  • Make scaleable template
    Posted by Thomas Baerten on February 15, 2019 at 10:01 am
    Hey Guys,
    I’m in charge of making nametags for the doors at my work.
    Problem is that we have different sizes, which makes it harder to adjust each nametag.
    Each time I find a new size I have to rearrange the design.
    Is there a way I can automate this? So the template can adjust itself in size, lay-out and fontsize depending on the input?
    Kalleheikki Kannisto replied 7 years, 6 months ago 2 Members · 1 Reply
  • Kalleheikki Kannisto
    March 6, 2019 at 10:55 am
    In Illustrator it would be scripting matter, so no easy solution there.
    If you have access to InDesign, it has an auto-layout function that attempts to fit the content when you change the page layout.
    Senior Graphic Designer
