Activity › Forums › Adobe After Effects › Make Reverse of Image Solid?
  • Make Reverse of Image Solid?
    Posted by Matthew Trundle on November 2, 2012 at 7:42 pm
    Perhaps I’m overlooking something simple: what is the best way to make the reverse of an image appear solid? For example, let’s say you import an image into a AE, make it 3D, and then rotate the image. As the reverse side of the image becomes visible, you will see that it is a mirror of the original; how does one go about making the reverse appear as a single color?
    Matthew Trundle replied 13 years, 11 months ago 4 Members · 4 Replies
  • Mathew Fuller
    November 2, 2012 at 8:25 pm
  • Walter Soyka
    A couple approaches:
    1. Create a solid the same size as your image, promote it to 3D, place it directly behind the image in z-space, and parent it to the image.
    2. Get fancy and use Dan Ebberts’s Layer Invisible When Facing Away From Camera [link] set of expressions.
    Walter Soyka
  • Darby Edelen
    November 2, 2012 at 9:09 pm
    [Walter Soyka] “1. Create a solid the same size as your image, promote it to 3D, place it directly behind the image in z-space, and parent it to the image.”
    You could also follow the same workflow by duplicating the image layer and applying Generate > Fill to the duplicate that you move behind the original. By its nature this will have the correct size and alpha as the original image.
    Darby Edelen
  • Matthew Trundle
    November 2, 2012 at 10:29 pm
    Thanks for your help. That’s what I was doing, I just wanted to see if there was something I was overlooking.
