Activity › Forums › Adobe After Effects › Make regular footage 16:9
Posted by Hamid Rohi-bilverdy on January 10, 2010 at 3:01 pmHi
If I import a regular footage from my phone or DV camera, how can I make the footage 16:9,in after effect so I get the black bars in top and bottom?
Or is this easyier in premier and how so?
Michael Szalapski replied 16 years, 7 months ago 4 Members · 3 Replies -
Todd Kopriva
January 10, 2010 at 4:49 pmIn After Effects, just drag the 4:3 footage into a composition that has the dimensions that you want and use the Fit To Comp Height command to scale the layer to match the vertical dimension of the 16:9 composition. This will leave “bars” on the left and right side.
putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment. -
Hamid Rohi-bilverdy
January 11, 2010 at 5:51 amHi
Thanks for reply. When you say this will leave “bars” on the left and right side? How come when I want the bars on the top and bottom, just like a widescreen movie.
I have not testet this yet, will do it later today.
Regards H
Michael Szalapski
January 11, 2010 at 5:21 pmThere are several ways to do this. I will list a couple.
1. In your original composition create a black solid. Mask out a bar shape. Put it at the top. Duplicate it. Put the duplicate at the bottom. (you can also create a Title in Premiere and create black rectangles like this.)
2. Drop your 4:3 footage into a 16:9 comp as Todd suggested, but instead of matching it vertically, scale it so it fills it horizontally. You won’t have black bars showing, but you will have proper anamorphic 16:9 like Hollywood DVD’s. That way you will get black bars when you play it on an old 4:3 TV, but when you show it on a 16:9 TV it will fill the screen rather than having black on the sides AND top and bottom.
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
