Activity Forums Adobe Premiere Pro Make Proxies Premiere
  • Make Proxies Premiere
    Posted by Fernando Alves on May 18, 2020 at 2:37 am
    Hello,
    I have some material in 4K and 6k from Alexa and Red. What I use to do, I transcode this material to Apple Pro Res Proxy and preserve the original frame size. I use this workflow because I don’t want to resize my material when I link to the original file. If the proxy is the same frame size of the original camera file, any scale intervention will be the same in both files. Am I right? Or can I transcode the file changing the frame size (example: 6k to 720p) and when I scale a proxy file image (720p) it will be the same when I relink to the original 6k câmera file? What is the right way to transcode a file? Preserve the original frame size or reduce it?
    I love Apple Pro Res Proxy. I can edit fast and the image quality is good, but the files are too large.Want to know others codecs that I can use. A codec similar to Pro Res Proxy( good image quality and fast to edit), but smaller files size. I have tried H264, but didn’t like it. Yes it is smaller, but it doesn’t play as smooth as Pro Res.
    Thanks a lot.
    Fernando Alves replied 6 years, 4 months ago 1 Member · 1 Reply
  • Fernando Alves
    May 19, 2020 at 1:04 am
    Hi Antoine Dorni,
    Nice one. Thanks for this article! Cristal clear. Solve my doubts about these issue.
    Take care.
