Activity Forums Maxon Cinema 4D make polygon thicker
  • make polygon thicker
    Posted by Hamid Rohi-bilverdy on March 29, 2014 at 5:22 pm
    Hi.
    Simpel question. Can i make a polygon thicker?
    I have created a camera projection of an image. In this image there is a door. I want to animate the door, so when door opens an emitter spits out objects. I have made a polygon selection of the door. Split it up, deleted the original so now i can animate the door. But the door polygon is so thin that my emitter objects sticks out!! How can i make the polygon thicker? I tried the bridge tool where i duplicated the door polygon, moved it 1 cm then bridged them, but then my uv mapping goes crazy??
    Please advice
    Br hrb
    Victor Camacho guerrero replied 12 years, 5 months ago 3 Members · 2 Replies
  • Brian Jones
    March 30, 2014 at 11:20 pm
    yes, extrude the door (the extrude tool not the extrude Nurb) or you can set your collision margins for the particles higher so it doesn’t poke through the door.
  • Victor Camacho guerrero
    March 31, 2014 at 11:21 am
    Did you try cloth nurbs?? I found it a really easy way to add thickness to things..
