Activity Forums Adobe After Effects make particles follow a trajectory
  • make particles follow a trajectory
    Posted by Prudence Saglisse on May 15, 2019 at 4:39 pm
    Hello everyone !
    I need your help for a problem that is blocking me.
    I’d like to do this : simulate a stream of particles, from point A to point B, following a precise trajectory.
    To make it as clear as possible I have concocted a beautiful scheme: https://www.dropbox.com/s/ruyd7alom90rn0h/4929_001_2.jpg?dl=0
    The expected rendering is similar to this, but with more complex trajectories: https://vimeo.com/286751571
    I tried to do something with the “particle lab” effect, but I can not achieve the desired effect.
    If you have a solution, and the patience to explain it to me in basic English (I’m French), I would be infinitely grateful.
    Thank you !
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Prudence Saglisse replied 7 years, 4 months ago 4 Members · 5 Replies
  • Greg Gesch
    May 15, 2019 at 11:22 pm
    Hi. Trapcode Particular allows particles to follow paths:
    https://www.youtube.com/watch?v=rV56P-MG0ms
  • Prudence Saglisse
    May 16, 2019 at 9:16 am
    Yes, but trapcode particular costs 400$… and I don’t have this money.
    Is there another solution.. ?
  • Cassius Marques
    May 16, 2019 at 12:08 pm
    The is also another paid plugin called Stardust (that may be a bit cheaper than Particular)
    You could try the free DuStroke. It’s not for that specifically but from the preview it seems one can do that.
    If those two options don’t work, you’d better get to animating that by hand because I’m out of ideas. It will take you a couple of hours, but its doable.
    Cassius Marques
    http://www.zapfilmes.com
  • Tomas Bumbulevičius
    May 16, 2019 at 1:10 pm
    Here is a tutorial, which might help:
    https://www.youtube.com/watch?v=rF5ogZAUkcc
    At least you wouldn’t need animating this plainly by hand. And by a chance of some controls tweaking and multiple bursts of effect from the same point, it might get you there.
    Find out more:
    After Effects Tutorials: motion design, expressions, scripting.
  • Prudence Saglisse
    May 16, 2019 at 2:03 pm
    DuStroke seems great !
    Thanks, I think I can do it now 🙂
