Activity › Forums › Adobe After Effects Expressions › Make Opacity 0 In Negative Z Space
  • Make Opacity 0 In Negative Z Space
    Posted by Guiboche on May 15, 2006 at 12:39 am
    Hello,
    I was just wonder, how might you use an expression to control a layer’s opacity when it moves beyound 0 in the 3D world.
    I understand that 0,0,0 = X,Y,Z
    When a layer moves into negative values into Z based on it’s world position, not by actually moving it, I want the opacity to = 0.
    Example, I have a layer attached to a null, and the null is rotating on the Y. When the layer connected to the null moves into negative world space on the Z, I want it’s opacity to = 0.
    Below is what I want to do:
    In the above example, opacity is dipping down when the layer moves into negative Z space. How might I do this with expressions?
    Thanks a lot 🙂
    Guiboche
    Guiboche replied 20 years, 4 months ago 1 Member · 1 Reply
  • Guiboche
    May 15, 2006 at 3:31 am
    Well, no one replied yet, but I figured it out 🙂
    The expression is
    a = toWorldVec([0,0,1]);
    b = position – toWorld(anchorPoint);
    c = dot(a,b)/length(b);
    if (c > 0) 0 else value
    You change the 0,0,1 to 0,0,-1 for in front or behind.
    Later
    Guiboche
