Activity › Forums › Adobe After Effects › make multiple proxies at once
  • Mylenium
    October 23, 2006 at 5:22 pm
    You could always add the items in question to the render queue, render out at half or quarter res and then use “Set Proxy”. The result and the process are pretty much the same…
    Mylenium
    [Pour Myl
  • Jeremy Webb
    October 23, 2006 at 5:27 pm
    but then i would have to set proxy for each item individually right?
  • Mylenium
    October 23, 2006 at 6:20 pm
    Sure. But you can’t have both, well at least not without a little help. I believe it would be easily possible cobbling up a script for that, but I’m not aware that such a thing already exists. So maybe check the usual sources such as AEnhancers.com or nabscripts.com
    Mylenium
    [Pour Myl
  • Roland R. kahlenberg
    October 23, 2006 at 10:18 pm
    I would create a Template for proxies that suits your requirements. Then simply select a footage in the Project Window and hit the key combo – CTRL+ALT+P. This sets the Render Queue ready with the proxy set to import as proxy for the selected clip. Quick and easy.
    The only thing easier would be to do the script thing that Mylenium mentioned.
    HTH
    Roland Kahlenberg
    broadcastGEMs
    customizable animated backdrops with Adobe After Effects project files”
