Activity Forums Adobe After Effects Make Fire Flicker
  • Make Fire Flicker
    Posted by Kevin Gonzales on March 22, 2008 at 2:50 pm
    OK, all Im trying to do is to make a photoshop layer of a fire flicker. I’ve played around with opacity but going in and setting key frames every few frames is a pain in the ass. Does anyone have a better suggestion.
    thanks.
    Nate Hanson replied 18 years, 5 months ago 2 Members · 1 Reply
  • Nate Hanson
    March 22, 2008 at 7:12 pm
    If you need to randomly change the opacity level every few frames, use the wiggle expression.
    Alt-Click on your opacity stop watch, then type:
    wiggle(frequency, amount)
    Example:
    wiggle(12, 5) – this would modify the opacity 12 times per second, by five units each time. So if your opacity is set to 50%, this expression would adjust your opacity from 45 – 55 percent, twelve times each second.
    Here is a tutorial by Andrew Kramer in case that doesn’t make sense:
    https://www.videocopilot.net/basic/ae_expressions.html
    Hope that helps,
    Nate
