Activity Forums Compression Techniques make fails when building with libx264 – osX
  • make fails when building with libx264 – osX
    Posted by Stephen Dixon on December 28, 2011 at 12:16 pm
    I’m building the 0.9 version of ffmpeg, on os X 10.6.8, and I can’t get it to compile with libx264. During the configure I get an error
    ERROR: libx264 version must be >= 0.118
    but I have libx264 0.120 installed, pulled off the x264 git repository today.
    $ x264 -V
    x264 0.120.x
    (libswscale 2.0.0)
    (libavformat 53.6.0)
    built on Dec 28 2011, gcc: 4.2.1 (Apple Inc. build 5666) (dot 3)
    configuration: --bit-depth=8 --chroma-format=all
    x264 license: GPL version 2 or later
    libswscale/libavformat license: GPL version 2
    I tried commenting out the line in the configure script that checks the version, and it compiled without any further errors, but when I ran make it died when it started doing x264 stuff:
    libavcodec/libx264.c: In function ‘convert_pix_fmt’:
    libavcodec/libx264.c:258: error: ‘X264_CSP_I422’ undeclared (first use in this function)
    libavcodec/libx264.c:258: error: (Each undeclared identifier is reported only once
    libavcodec/libx264.c:258: error: for each function it appears in.)
    libavcodec/libx264.c:261: error: ‘X264_CSP_I444’ undeclared (first use in this function)
    libavcodec/libx264.c: In function ‘X264_init’:
    libavcodec/libx264.c:318: warning: ‘crf’ is deprecated (declared at libavcodec/avcodec.h:2667)
    libavcodec/libx264.c:320: warning: ‘crf’ is deprecated (declared at libavcodec/avcodec.h:2667)
    libavcodec/libx264.c:321: warning: ‘crf_max’ is deprecated (declared at libavcodec/avcodec.h:3059)
    libavcodec/libx264.c:322: warning: ‘cqp’ is deprecated (declared at libavcodec/avcodec.h:2675)
    libavcodec/libx264.c:324: warning: ‘cqp’ is deprecated (declared at libavcodec/avcodec.h:2675)
    libavcodec/libx264.c:357: warning: the address of ‘val’ will always evaluate as ‘true’
    libavcodec/libx264.c:364: warning: ‘aq_mode’ is deprecated (declared at libavcodec/avcodec.h:3018)
    libavcodec/libx264.c:365: warning: ‘aq_mode’ is deprecated (declared at libavcodec/avcodec.h:3018)
    libavcodec/libx264.c:366: warning: ‘aq_strength’ is deprecated (declared at libavcodec/avcodec.h:3026)
    libavcodec/libx264.c:367: warning: ‘aq_strength’ is deprecated (declared at libavcodec/avcodec.h:3026)
    libavcodec/libx264.c:368: warning: ‘psy_rd’ is deprecated (declared at libavcodec/avcodec.h:3034)
    libavcodec/libx264.c:369: warning: ‘psy_rd’ is deprecated (declared at libavcodec/avcodec.h:3034)
    libavcodec/libx264.c:370: warning: ‘psy_trellis’ is deprecated (declared at libavcodec/avcodec.h:3042)
    libavcodec/libx264.c:371: warning: ‘psy_trellis’ is deprecated (declared at libavcodec/avcodec.h:3042)
    libavcodec/libx264.c:372: warning: ‘rc_lookahead’ is deprecated (declared at libavcodec/avcodec.h:3050)
    libavcodec/libx264.c:373: warning: ‘rc_lookahead’ is deprecated (declared at libavcodec/avcodec.h:3050)
    libavcodec/libx264.c:374: warning: ‘weighted_p_pred’ is deprecated (declared at libavcodec/avcodec.h:3008)
    libavcodec/libx264.c:375: warning: ‘weighted_p_pred’ is deprecated (declared at libavcodec/avcodec.h:3008)
    libavcodec/libx264.c:376: warning: ‘bframebias’ is deprecated (declared at libavcodec/avcodec.h:2705)
    libavcodec/libx264.c:377: warning: ‘bframebias’ is deprecated (declared at libavcodec/avcodec.h:2705)
    libavcodec/libx264.c:378: warning: ‘deblockalpha’ is deprecated (declared at libavcodec/avcodec.h:2729)
    libavcodec/libx264.c:379: warning: ‘deblockalpha’ is deprecated (declared at libavcodec/avcodec.h:2729)
    libavcodec/libx264.c:380: warning: ‘deblockbeta’ is deprecated (declared at libavcodec/avcodec.h:2737)
    libavcodec/libx264.c:381: warning: ‘deblockbeta’ is deprecated (declared at libavcodec/avcodec.h:2737)
    libavcodec/libx264.c:382: warning: ‘complexityblur’ is deprecated (declared at libavcodec/avcodec.h:2721)
    libavcodec/libx264.c:383: warning: ‘complexityblur’ is deprecated (declared at libavcodec/avcodec.h:2721)
    libavcodec/libx264.c:384: warning: ‘directpred’ is deprecated (declared at libavcodec/avcodec.h:2756)
    libavcodec/libx264.c:385: warning: ‘directpred’ is deprecated (declared at libavcodec/avcodec.h:2756)
    libavcodec/libx264.c:386: warning: ‘partitions’ is deprecated (declared at libavcodec/avcodec.h:2744)
    libavcodec/libx264.c:387: warning: ‘partitions’ is deprecated (declared at libavcodec/avcodec.h:2744)
    libavcodec/libx264.c:389: warning: ‘partitions’ is deprecated (declared at libavcodec/avcodec.h:2744)
    libavcodec/libx264.c:391: warning: ‘partitions’ is deprecated (declared at libavcodec/avcodec.h:2744)
    libavcodec/libx264.c:393: warning: ‘partitions’ is deprecated (declared at libavcodec/avcodec.h:2744)
    libavcodec/libx264.c:395: warning: ‘partitions’ is deprecated (declared at libavcodec/avcodec.h:2744)
    libavcodec/libx264.c:537: warning: ‘crf’ is deprecated (declared at libavcodec/avcodec.h:2667)
    make: *** [libavcodec/libx264.o] Error 1
    I can compile without -enable-libx264, my configure line looks like:
    /configure --enable-gpl --enable-nonfree --enable-frei0r
    --enable-libaacplus --enable-libfaac --enable-libmp3lame
    --enable-libtheora --enable-libnut --enable-libaacplus
    --enable-libx264
    Anyone have nay ideas about what is going on? Thanks.
    Stephen Dixon replied 14 years, 9 months ago 2 Members · 3 Replies
  • Reuben Martin
    December 28, 2011 at 8:37 pm
    x264 != libx264
    You may have built a static x264 binary that didn’t result in libx264 being installed. Check the library that ffmpeg is trying to link to and make sure that it is the correct version.
    It’s also possible to have multiple versions of the library installed and the linker may be grabbing the earlier version. The file libx264.so is generally a softlink to the version of the library. It may still point to an older library. Make sure it points to libx264.so.120
    Make sure the older libraries and include files are removed, and that any softlinks resolve to the current versions.
  • Stephen Dixon
    December 28, 2011 at 10:59 pm
    Thanks. I’m guessing they’ll be in /usr/local/lib?
  • Stephen Dixon
    December 29, 2011 at 1:14 am
    Removed all traces of x264 and it seemed to work. Interestingly I had to specifically enable shared libraries when I built x264 again, because it’s off by default.
