Activity › Forums › Adobe After Effects › Make Card Dance Simulation boxes 3D
  • John Cuevas
    August 18, 2012 at 1:02 pm
    Don’t think you could accomplish it with card dance, but you should be able to accomplish that with Shatter, using a gradient layer to control the AE’s shatter. You could even make a custom shatter map to absolutely control how the transformer breaks up. Then you would just have to precomp your shatter animation and time remap it backwards.
    Here’s a pretty good tutorial on the basics of shatter.
    Also Element from video copilot looks like it could be up to the task also. But it requires a little more prep work in a 3D program, check out this tutorial at 20:00.
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Vishesh Arora
    August 18, 2012 at 4:04 pm
    Thanks Mr. Cuevas.
    I don’t have Element 3D but I can use that shatter simulation . Thanks for the links 🙂
    Vishesh Arora
    VFX and Motion Graphics Artist
    https://digieffects.wordpress.com
