Activity › Forums › Adobe After Effects › Make an object reflecting on real water footage in AE CC 2017
  • Make an object reflecting on real water footage in AE CC 2017
    Posted by Margaux Millet on February 17, 2018 at 5:45 pm
    Hello everyone,
    I have a problem to make an effect in AE. I have a comp representing an animated graph (I use the motion tracking) in 3D. I also have a footage of a river. I want my graph to reflect on the river. Do you know if it’s possible and if so, how could I create this effect?
    Thank you very much in advance
    Jim Scott replied 8 years, 7 months ago 2 Members · 1 Reply
  • Jim Scott
    February 17, 2018 at 7:16 pm
    Duplicate your graph layer. Make it 3D. Adjust its position, orientation and scale so as to make it appear as a mirror image of the original in the plane of the water. Reduce its opacity to make it appear as a reflection. Apply Effect > Distort > Displacement Map and select the water footage as the displacement map layer. Adjust the displacement settings to your satisfaction.
    Hope this helps.
