Activity Forums Apple Final Cut Pro make a timeline with properties larger than clips
  • make a timeline with properties larger than clips
    Posted by Anton Hecht on November 20, 2014 at 10:21 am
    Hi, hope this makes sense, I am doing a project where I need to slide edit footage across the screen from one side to another, for a 3 screen video projection. Can I make a timeline that is the same height as clips, but is three times as long, so I can do the slide edit. Thanks. I know that 2 third of screen will be empty at any time, which is what I want. thnaks.
    Jeff Kirkland replied 11 years, 9 months ago 2 Members · 3 Replies
  • Jeff Kirkland
    November 20, 2014 at 11:26 am
    Yes, you can do that. Just set the dimensions to whatever you need when you create a project.
    Jeff Kirkland | Video Producer | Southern Creative Media | Melbourne Australia
    http://www.southerncreative.com.au | G+: https://gplus.to/jeffkirkland | Twitter: @jeffkirkland
  • Anton Hecht
    November 20, 2014 at 2:21 pm
    Thanks, that seems to work, though am wondering, the clips are interlaced, but when I make the custom size it only allows progressive, is this ok, will it convert the interlaced to progressive. thanks again.
  • Jeff Kirkland
    November 20, 2014 at 7:13 pm
    FCPX will deinterlace on export, or the better option might be to select the clips in the browser, go to the info panel and tell FCPX to deinterlace them before you start editing.
