Activity Forums Apple Final Cut Pro Legacy Make A Texture Map in FCP???
  • Make A Texture Map in FCP???
    Posted by Max Frank on September 14, 2006 at 10:25 am
    I want to know if my garden variety FCP HD can do the following:
    I want to overly a clients logo over a curtain background, and then have the logo look as if it’s blended with the curtain as it moves at the same time as the curtain.
    I believe this is called texure mapping.
    I know I can do it in Motion and AE, but I don’t have either.
    I do have Boris Continuum, if that helps.
    Any guidance will be greatly appreciated.
    Wayne
    2DP G5, 3.5GB RAM, FCP HD
    Kevin Monahan replied 19 years, 11 months ago 2 Members · 1 Reply
  • Kevin Monahan
    September 15, 2006 at 1:17 am
    If you have my book, you also will have Telly’s FX written by Graeme Nattress.
    Tellys FX > Telly’s Bumpmap
    Add the filter to the text clip
    Drop the curtain clip into the well (Unlike the FCP version, the “WELL” is unlocked.
    Tweak to taste
    Otherwise, you’ll need AE.
    BCC has displacement but not bumpmapping.
    Kevin Monahan
    Take My FCP Master’s Workshop!
    fcpworld.com
    Pres. SF Cutters
