Activity Forums Apple Motion Make a single ray of light gradually fade out on one end –
  • Make a single ray of light gradually fade out on one end –
    Posted by Terry Maloney on January 27, 2021 at 1:02 am
    Yes, I know about turning down the opacity of an object as it moves in the timeline with keyframes. I’m not talking about this. I’m talking about drawing one line which looks like a ray of light – the further to the end of the line, it fades out like a light. Then I can multiply them and surround an object with them and it will give the illusion that the object has light coming from it. Then I can use key frames to make the lines longer or bigger to make the illusion that the object is getting brighter.
    Thanks for your help. Terry
    Terry Maloney replied 5 years, 7 months ago 1 Member · 1 Reply
  • Terry Maloney
    January 29, 2021 at 9:21 pm
    Hi. I found the answer. I can use time trails. Thank you.
