Activity Forums Adobe After Effects make a sign in AE
  • make a sign in AE
    Posted by Darideas on May 16, 2006 at 2:33 am
    HELLO I need help I need make a animation in AE the idea is i have a hand with a pencil and i want make a sign, I meke this with MOTION SKETCH but its slow I need the movement faster, IF any can help please answer.
    If I can make with oder optior or anyway
    I only need de movement of the hand with the pencil
    daniel
    Aharon Rabinowitz replied 20 years, 4 months ago 4 Members · 3 Replies
  • Joe Chao
    May 16, 2006 at 7:03 am
    go to the layer you add key frames to,push “u”.now U must be able to see the key frames u have made by MOTION SKETCH.select them all, hold down you “Alt” key on the keyboard,drag the last key frame,now ,u can adjust the speed:)
  • Mark
    May 16, 2006 at 10:32 am
    I usually use vector paint as a track matte for the original for this kind of thing.
    I set the shift paint records to capture in realtime, then trace the original element. Upon completion, I set the vector paint to animate all strokes, then adjsut the playback speed of vector paint accordingly.
    Mark
  • Aharon Rabinowitz
    May 16, 2006 at 1:10 pm
    All good advice. Although motion sketch creates a keyframe at every frame. You may need to run it through the Smoother and reduce keyframes before compressing them with the Alt+Drag approach, suggested by Joe.
    Another option is to precomp the motion sketched layer and either time stretch it or time remap it to make it faster.
    As if that wasn’t enough, you can also set the motion sketch to capture your motion at different speeds, so you can have you moving at a natural speed, but the motion ends up being twice as fast.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
