Activity Forums Adobe After Effects Make a rat talk? – How do you do it?
  • Make a rat talk? – How do you do it?
    Posted by Brian Tetamore on October 12, 2005 at 8:37 pm
    Got a short story in development where the main character will be a live rat. It only has a couple of lines. Anyone have any suggestions to make this happen? Wondering if you can use the audio keyframes to add an expression to a selected area…his mouth?
    Eric Christians replied 20 years, 11 months ago 4 Members · 3 Replies
  • Dr. Sizzle
    October 12, 2005 at 9:52 pm
    You might want to look into the Dr. Doolittle DVD making. what they did was motion tracked the face and made the animation seperately.
  • Graham Quince
    October 13, 2005 at 7:38 am
    There was a discussion here a little while ago about using time remapping controlled by an expression.
    I think you could get a shot of the rat’s mouth open and one of it closed, then use the audio-to-keyframes feature to create a set of time remapping keyframes to sync up the rat to the voice. Unfortunately i can’t help you with the expressions bit, but maybe a search here would find you the answer.
    Good luck
    Graham
    http://www.qcit.com
  • Eric Christians
    October 13, 2005 at 2:02 pm
    You can always try the Mr. Ed method…
    Give the animal a bit of peanut butter to smack its lips on…
    That’s what they did for the horse on the Mr Ed show…They smeared a bit of peanut butter on his bridle & bit and let him try to lick it to get get his lips to move..
    –Very low tech idea–
    For more control I would go with the time-remapping & expression
    …or if you have time and $$, for complete & total control go the 3D animation route…
    Just my two cents…
