Activity › Forums › Adobe After Effects › make a psd layer into a mask for layer below in AE
  • make a psd layer into a mask for layer below in AE
    Posted by Katherine Clark on September 5, 2012 at 4:29 am
    I have a black layer with transparency where I want to mask out the layer below. I can reverse this if needed. I remember using luma matte to mask a layer underneath a solid black or solid white layer, but I cannot seem to remember the right way to do this. So how can I us a psd layer to mask a layer or comp that is below it?
    Jeff Hinkle replied 14 years ago 2 Members · 1 Reply
  • Jeff Hinkle
    September 5, 2012 at 2:05 pm
    Put your black and white layer (we’ll call it A) above the layer you want to mask (B). Set the Track Matte (shows up as TrkMat in the timeline panel; you may need to hit the “Toggle Switches/Modes” button if you don’t see it) on layer B to Luma Matte. Anyplace that’s black in A will be transparent in B, anyplace white will be visible. Anything gray will give partial transparency.
    Now, if A is a black layer with transparency, you’ll want to use an Alpha Matte. Same principle, but anyplace that’s opaque will be visible in B and anything transparent will likewise be transparent. If you’re going Alpha Matte, the opaque area color is irrelevant. It could be black, white, rainbow colored, a lovely photo of a sunset, doesn’t matter. All After Effects looks at is opacity.
    It is easier to destroy than to create.
    More fun, too.
