Activity › Forums › Adobe After Effects Expressions › make a layer move away from point (expression)
  • make a layer move away from point (expression)
    Posted by Erin Shelby on April 9, 2006 at 5:01 am
    So let’s say I have a small 10×10 solid and a null object. Over time, I would like the Solid to move at a constant rate away from the null. Is this possible? I can elaborate if reqired, but basically it should almost look like a single particle moving away from the source point of a particle engine. Is that possible?
    -echo
    Sam Moulton replied 20 years, 5 months ago 3 Members · 3 Replies
  • Dan Ebberts
    April 9, 2006 at 6:21 am
    You might start with something like this:
    angle = 45; // angle of travel away from null
    spd = 200; // speed (pixels per second)
    rads = degreesToRadians(angle);
    xComponent = Math.cos(rads);
    yComponent = Math.sin(rads);
    thisComp.layer(“Null 1”).position + [xComponent,yComponent]*spd*time;
    Dan
  • Dan Ebberts
    April 9, 2006 at 6:25 am
    If you wanted to create more of an explosion, you could use something like this and duplicate your layer a bunch of times:
    seedRandom(index,true);
    angle = random(360); // angle of travel away from null
    spd = random(150,400); // speed (pixels per second)
    Dan
  • Sam Moulton
    April 9, 2006 at 10:47 pm
    this is a really good expression that solved a problem for me. It’s in my notebook. Thanks Dan!
