Activity Forums Adobe After Effects Expressions Make a function to add in the render queue with own specifications.
  • Make a function to add in the render queue with own specifications.
    Posted by Adrián Wulfrath on April 6, 2016 at 3:37 pm
    im actually doing a button to make a function, to add a specific comp to the render queue, but with own specifications, something like AppleProRes codec, Unmatted, Alpha and with another button specify the output path.
    this is what i have actually:
    btn.onClick = function()
    //here the code to add the specific comp to render queue with my configuration
    Adrián Wulfrath replied 10 years, 5 months ago 1 Member · 1 Reply
  • Adrián Wulfrath
    April 6, 2016 at 4:12 pm
    Now i got this:
    But how to specify the output and settings?
    var QTtemplate = "Alpha Only";
    var activeItem = app.project.activeItem;
    var sel = app.project.item(1);
    if (sel != null && sel instanceof CompItem) {
    var theRender = app.project.renderQueue.items.add(sel);
    if (sel.height < 32) {
    theRender.outputModules[1].applyTemplate(QTtemplate);
    } else {
    alert("Select the comp you want to render first");
