Activity › Forums › Adobe After Effects › .make a “feet+frames” film counter in AE
  • .make a “feet+frames” film counter in AE
    Posted by Lori Kundrat on September 14, 2006 at 4:32 am
    Hi everyone-I’m trying to make a film style “feet+frames” counter display in After Effects. I’ve tried some experiments w/ the Text/Numbers effect, but no lock…I’m not real good w/ expressions…If anyone who has an idea on how to do this, I would sure appreciate it! Thanks, Lori
    Sam Moulton replied 20 years ago 3 Members · 2 Replies
  • Steve Roberts
    September 14, 2006 at 5:04 am
    Did you try effect>text>timecode, setting the display format to “feet + frames” ?
  • Sam Moulton
    September 14, 2006 at 5:55 am
    in the expression language menu under “Global” you’ll find a bunch of expressions already written for you that use the time of the comp to generate counters.
    Time to feet and frames is one of them. Just start a new text layer and add the expression to the source text property then set the number of frames per foot. It couldn’t be easier. I think it defaults to 35mm, 16mm is 40 frames per foot, 35mm is 16.
    make sure you pick a monospaced font so the numbers don’t jump around. the expression language menu is right next to the pickwhip and look like a little triangle.
