Activity › Forums › Adobe After Effects › make a cylinder from a solid
Posted by Benito Sanz on April 14, 2005 at 10:51 pmhi people how do you make a cylinder from a solid layer, lets say 500×100.
thank a lot
Chris Smith replied 21 years, 5 months ago 3 Members · 6 Replies -
Chris Smith
April 14, 2005 at 10:53 pm -
Benito Sanz
April 14, 2005 at 10:56 pmthank chirs for your quick reply but i have 6.0, any other work around.
thanks
Chris Smith
April 14, 2005 at 11:01 pmIf you happen to own invigerator, import a circle and extrude it. Then map your texture onto it.
Or better yet generate the cylinder in 3D and render out the images to comp in with the rest of your project.
I know this may not be what you want to hear, but the $99 upgrade to 6.5 is the best $99 you will ever spend in your entire life. You get a full set of CC plugs, Color FInesse (!!!!), more powerful AE. They gave well over a thousand dollars of goodies for you for a paltry price. I consider it incredibly generous on Adobe’s part and I recommend taking advantage of it.
my .02
Chris Smith
https://www.sugarfilmproduction.com -
Benito Sanz
April 14, 2005 at 11:07 pmthanks chris, i am gonna do the update soon, i know is a very good deal, but i needed to buy a video card first, over here in the uk is all 30% more expensive than usa.
thanks anyway for your help, very appreciated
Joe Chao
April 15, 2005 at 1:45 amFE cylinder can also make it.It’s almost the same with CC cylinder,and can be installed in AE6.0.
Buy the way,CC cylinder can also installed with AE6.0.(if you happened to have a install pack of it) -
Chris Smith
April 15, 2005 at 5:11 amFE and CC should be identical. CC is the Final Effects plug-in suite now put out by Cyclore.
Chris Smith
