Activity Forums Apple Final Cut Pro Legacy MAJOR SYNC PROBLEM
  • MAJOR SYNC PROBLEM
    Posted by David Reichelt on November 6, 2007 at 1:44 am
    Hi I am working on a short film. The director synced up everything before giving it to me and now every master clip is 2 frames out of sync with one master clip 8 frames out of sync. I was going to just fix it in the time line but then I realized that I wouldn’t have a master clip that was in sync; I’d just have it in sync in the time line. Is there a way to sync up the master clip in the time line and then duplicate it so I have a master clip that is now in sync? So that I am as clear as I can be, I want to create a new master clip after having synced up the original master clip. Any advice will be much appreciated. Thank you
    Katie Gillum replied 18 years, 1 month ago 5 Members · 14 Replies
  • 14 Replies
  • Jeremy Garchow
    November 6, 2007 at 3:58 am
    Was the audio captured with video or was your audio recorded separately?
    Jeremy
  • David Reichelt
    November 6, 2007 at 5:02 am
    It was recorded separately
  • Jeremy Garchow
    November 6, 2007 at 5:15 am
    Then I am confused. If he gave it to you in sync, but now it’s out of sync, and you want to resync it, why don’t you just resync it and relink?
    Jeremy
  • David Reichelt
    November 6, 2007 at 5:19 am
    When it was given to me in the quick time format after they synced it up it was out of sync by two frames already. What I really want to know is the workflow for making the master clip I put in the time line a new master clip after I unlink it to sync it up in the time line.
  • Jeremy Garchow
    November 6, 2007 at 5:24 am
    Unlink Video and audio, sync, link video and audio. It’s that easy.
  • Jeremy Garchow
    November 6, 2007 at 5:31 am
    If you need a master clips in the borswer, you drag that new synced clip up to the browser and right click and choose ‘Make Master Clip’
  • David Reichelt
    November 6, 2007 at 6:17 am
    Ok well that’s pretty simple. Yeah my goal was to make a master clip out of the newly synced clip. Thank you for the tip.
  • Gary Adcock
    November 6, 2007 at 2:25 pm
    [hawktroop] “When it was given to me in the quick time format after they synced it up it was out of sync by two frames already”
    Most HD content is laid down 2 frames out of sync, DVCPROHD is notorious for this, most of the workflows ( FCP for example) handle this on ingest via tape- if it was from tapeless production it becomes the editors job however.
    [hawktroop] “What I really want to know is the workflow for making the master clip I put in the time line a new master clip after I unlink it to sync it up in the time line”
    The easiest was is to just relink the footage in the timeline to the new corrected clip.
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows
    https://library.creativecow.net/articles/adcock_gary/AJAIOHD.php
  • Jeremy Garchow
    November 6, 2007 at 4:02 pm
    No worries. Hope it helps.
    Jeremy
  • Christina Knickerbocker
    March 13, 2008 at 3:22 am
    Hey, hoping you can help me with this:
    I followed your directions–I drug the clip to the timeline, unlinked, re-synched, then re-linked. But when I drag the clip back to the browser, the audio doesn’t come with it. I’ve checked and re-checked–they are definitely linked. But only the video part of the clip is dragged to the browser. I have to have a re-synched master clip. Any suggestions?
    thanks!
