Activity Forums Adobe Encore DVD Major Project, Major Headache!
  • Major Project, Major Headache!
    Posted by Hisods on January 25, 2006 at 7:01 pm
    I shot a series of 15 second clips about a year ago to go into a software ap. Now the client wants to burn them out to DVD for set top playback. There are 300 clips under some 18 categories. This would require 18 menus with up to 20 sub menus per category menu. 🙁
    I have Encore 1.5 and have never tried anything like this. Is it up to the task? Should I invest the money for the 2.0 upgrade and some Total Training? Is there a better software ap out there?
    I realize that I am out of my depth; having VERY little DVD experience other than straight burning. I use a Plextor 708 burner. I should mention that the initial run of these will be about a thousand copies so I need to make it real correct like.
    thanks in advance for all sage advice!
    Steve
    Aanarav Sareen replied 20 years, 8 months ago 3 Members · 2 Replies
  • Dominic Osborne
    January 25, 2006 at 11:58 pm
    I think you are worrying for no reason….
    You’d start with a main menu for a choice of the 18 categories, with each sub-menu having 20 or so choices as you described. If you are working in 4:3 then you can have (if memory serves) 36 buttons on a menu, as opposed to 18 buttons on a 16:9 menu.
    Create your menus in photoshop (you use this, right?), import all your assets – vid clips etc, make you timelines, one category at a time, and link each button to each timeline – you should be able to keep fairly good track of where you are if you break it into chunks like this….
    Dominic Osborne
    Director & Head of Visuals
    Eight Eyed Sea Bass Ltd
    http://www.eighteyedseabass.com
  • Aanarav Sareen
    January 26, 2006 at 4:01 am
    Shouldn’t be a problem at all. HOWEVER, I would reccomend that you use a flowchard to assist you with this process, otherwise you can get lost.
