Activity Forums Boris FX Major Problems Rendering Extruted Text
  • Major Problems Rendering Extruted Text
    Posted by Rex Polanis on September 18, 2011 at 9:29 pm
    I am trying to render a comp with BCC7 extruded text and spline to avc format for output to BluRay. Every time I render the comp the extruded text and spline drop in and out over several frames creating a flashing effect over the course of the comp. It should remain solid the entire time. I have tried restarting Vegas and my computer and rendered the comp several times but the same thing happens every time. Please help. Thank you
    My System specs:
    Windows 7 64
    8 gigs of ram
    Nvidia gtx 550ti
    Sony Vegas Pro 10e
    BCC 7
    One man with courage makes a majority.
    Canon 7D
    Sony Vegas 10
    Adobe PhotoShop
    Glass Onion replied 14 years, 11 months ago 3 Members · 2 Replies
  • Peter Mcauley
    September 20, 2011 at 3:57 pm
    Hi Rex,
    It sounds like a memory related issue but we can’t be sure without more information. The first thing I would suggest would be to reduce the value in the Polygon Count parameter or maybe setting the antialiasing pop-up to good or draft. Perhaps if someone were to work with you on the phone we might be able to find a solution to the problem. Can you please call into out support group … you an reach them toll free at 1 888 772 6747. Or if you prefer email, try support@borisfx.com.
    Cheers,
    Peter.
  • Glass Onion
    September 20, 2011 at 9:03 pm
    I too get flashing frames with vegas 10 and boris 5. I updated my video card driver and it fixed the problem. Vegas & Boris still seem buggy and unreliable but at least now I stopped the flashing of wrong frames. Hope that helps.
