Activity Forums Adobe Premiere Pro Major problem with time code in 2.0
  • Major problem with time code in 2.0
    Posted by Timothy Eaton on June 10, 2006 at 5:15 am
    We are editing an offline project in PPro 2.0 which was begun in 1.5. We are working with roughly 60 hours of digitized material. Now that we’re 15 minutes deeper into the project we have noticed that 2.0 has converted our time code from non drop to drop frame and the numbers have shifted wildly and variably from 20 or 30 seconds off to more than a minute. It does not matter whether the 2.0 project setting is for non drop or drop, the numbers still shift.
    Could someone please check this anomaly? Try a simple offline entry in a PPro 2.0 project window, with the project set on non drop frame. Right click in the project window, select new item, then offline file. Enter code in the media start and media end boxes, then click OK. Now check the new files in and out code. It will have converted to drop frame and be significantly different from what was entered.
    Since we are going to online in HD, it is extremely important that our time code is accurate. I would love to hear that this is only a glitch in my software installation and it can be easily remedied. If it is not, then this issue has cost us an enormous amount of time (and expense). Any suggestions? Has anyone had these or similar issues?
    Tim
    Timothy Eaton replied 20 years, 3 months ago 3 Members · 4 Replies
  • Troy Murison
    June 10, 2006 at 7:36 am
    Hi Tim,
    I just created a ‘offline’ file in a new PPro 2.0 project
    that was set to be a NDF project and got similar problems.
    I created a offline clip with a reel number and tc set to
    the following:
    Media Start 01:00:00:00
    Media End 01:00:30:00
    Media Dur 00:00:29:29
    These are the immediate resulting clip values in the bin
    (still in NDF project):
    Media Start 01;00;03;18
    Media End 01;00;33;17
    Media Dur 00;00;30;00
    With a DF project, the same in points were used (; indicated
    that it was DF) and the clip’s points tracked fine, even after
    I then changed the project’s settings to NDF. However, subsequent
    newly created NDF offine files with the project set to NDF
    showed the same problem.
    Again, I had no media in the project, standard 48k DV 29.97 NTSC
    4:3 project setting to start. Don’t know what the results would
    be with captured clips from tape that have mixed format TC
    as I don’t have anything lying around and it’s late.
    Just to be sure I also tried a Adobe SD-SDI project setting on
    one machine too with the same results.
    I had given up on 1.5 with all it’s messed-up TC problems, and
    to be honest the (few) tests I have done to this point in 2.0
    have been mostly okay (not perfect though) but these tests have
    involved conforming EDLs created in Avid and FCP, which 1.5
    would totally hose-up. At least 2.0 gets that mostly right in
    my limited experience. But, I must say that this is very
    distrubing that these kinds of issues have not been properly
    addressed. I thank you for bringing it to my attention before
    I counted on it to do a offline project. I’m sure others will
    chime in and I am hoping there’s a simple fix or something I’m
    overlooking, but…
    I guess I don’t have any answers or help for you, but know that
    on my machines (I tried the same test on two) exhibit exactly the
    same results. I thought(hoped?) maybe I could disprove that 2.0
    was the culprit and that starting the project in 1.5 was the
    problem, but I guess not…
    Sorry to give you this news… Good luck,
    -Troy Murison
    Seattle, WA
  • Timothy Eaton
    June 10, 2006 at 1:59 pm
    Troy,
    Thanks very much for giving it a try. Maybe an Adobe connected reader will also take a look at this — it would be great to hear that there is some simple answer!
    I’ve been a long-time Premiere user and we’ve had various problems with time code in the past. But with 2.0 I assumed these problems would go away since there are other fine improvements. How hard can it be to write a software module that deals accurately with time code since it’s an absolutely essential component of video editing systems? I’m not going into full rant yet, but I’m thinking about those sixty hours of digitized footage duplicated on three Premiere offline systems with three editors using the same footage, several hours of selects, and fifteen minutes of edited program with hundreds of edits. Ouch.
    Thanks again Troy,
    Tim
  • Ken Adolph
    June 10, 2006 at 8:49 pm
    What is the original source footage? DV? HDV? Other?
    Ken Adolph
    Media Group
    Editor/Post Supervisor
    https://www.mg.ca
  • Timothy Eaton
    June 10, 2006 at 10:51 pm
    Ken,
    The source material is DVCPro HD from a Panasonic AJ HD1200 deck outputing composite SD video for offline editing, digitized with a Matrox RTx.100 card. But 2.0 converts all of that code to drop frame even if I unlink the video files and make them all offline, so they are no longer seen as a Matrox DV file, and in the process of converting them to drop frame, it offsets them dramatically and unpredictably. This is why I decided to see what would happen if I simply created an offline file in the project window. I was willing to re-enter all of our digitized files manually from an old list. (You can try it yourself — it only takes about ten seconds to create one) But the fact that 2.0 alters the simplest user created offline file, essentially making it useless for digitizing rules that plan out. I’m hoping to hear there is a simple solution (not a workaround) for this.
    Thanks for any help you can give. Tim
