Activity › Forums › Media 100 › MAJOR MAJOR MAJOR Program crashes
  • MAJOR MAJOR MAJOR Program crashes
    Posted by David Issko on November 14, 2007 at 9:12 am
    My HDe has suddenly played up on 2 different projects.
    Both have the same fault. The projects has various programs, some that open up instantly and others that cause M100 to crash and the bug reporter window opens.
    This is a serious issue that I don’t know what is causing programs to cause such a problem.
    David C or Floh, any ideas please? Anyone else too.
    David Issko
    David Issko replied 18 years, 10 months ago 4 Members · 4 Replies
  • Felix Halter
    November 14, 2007 at 10:29 am
    Probably a corrupt media file, the same one in all the crash programs. Try to delete it in the finder before opening the program.
    Felix
  • Floh Peters
    November 14, 2007 at 10:37 am
    First, you definitely should send the crashlogs, including your email-address and any details you can give. It is very important for the engineers to know as much details as possible with these logs.
    Second, it sounds like you have either a harddrive or media file problem. I would run Apple Disk Utility to check your media drives, and DiskWarrior if you have it. You also can unmount your media drive and load your projects to see if the timelines also crash without linking to the media files.
    If then your timelines open fine, and if you checked your drives you can try finding out which media file is the problem. I would create a new project and open one of the offending timelines into it (without allowing the relink media automatically). Then create a new folder on your media drive, add that to the Projects media locations, and start moving media files into this folder and switching back to Media 100. Do you get a crash somewhere along moving files into it? Then you probably have found your bad media file.
    Are there elements that are shared across your projects? Maybe one of those elements is the cause for the problems.
  • Scott_f Media 100
    November 14, 2007 at 2:00 pm
    Put your contact information in the Bug reporter so we can contact you to get more information on the crash.
    Scott
  • David Issko
    November 14, 2007 at 9:52 pm
    Thanks guys,
    I have tried a few things, but to no avail. Luckily my backups helped me out quickly as I will have to complete this important project very soon. Thanks for your prompt replies.
    Cheers
    David Issko
