Activity › Forums › Apple Final Cut Pro › major issues with color matching
Posted by Shane Trowbridge on January 6, 2012 at 8:31 pmI am having MAJOR issues with matching color within FCPX. Their matching color feature was supposed to be the next best thing to sliced bread but I have had nothing but major issues. I’m not talking about slight issues. I’m talking about taking a non color corrected interview clip and trying to match it to an already color corrected clip from the same interview. When I try to match the color it will turn the new clip greenish or off yellow or something crazy to that effect. Anyone else having similar issues or know a solution?
Thomas Frank replied 14 years, 8 months ago 7 Members · 6 Replies -
Oliver Peters
January 6, 2012 at 8:40 pmThis feature does not work well. Color matching changes the color in the color profile of the clip, so the actual changes made are invisible. It does not make changes in the Color Board. So if you have color corrected a shot using the Color Board and then try to use Color Match to match another clip to those adjustments, an entirely different process is used. In fact, you can color match the same clip to itself (without any color correction) and the results will be a slight change to the matched clip, thus indicating that the process isn’t truly transparent (when it should be in this example). It’s a real hit-or-miss feature and I find it pretty much useless.
– Oliver
Orlando, FL
http://www.oliverpeters.com -
Steve Connor
January 6, 2012 at 9:23 pm[Oliver Peters] “and I find it pretty much useless.”
He’s right, it’s not very good at all !
Steve Connor
“FCPX Agitator”
Adrenalin Television -
Matthew Celia
January 7, 2012 at 12:34 amI’ve had decent luck with it. As with anything that’s automatic, I find it is helpful to try and match shots that are fairly similar. Two medium close ups of people in similar environments, or a multi-cam shoot (for example). It really falls apart when you try and match, for another example, a really dark shot with a really light shot.
I prefer to do it manually any way – hoping they add a still store / split screen feature to coloring so we can compare a bit easier.
FCP Guru
http://www.fcpguru.com -
T. Payton
January 7, 2012 at 1:02 amBefore you throw completely disgard Color Match, I agree it gives odd results sometimes, but other times it is pretty fantastic. Take a look at this quick keying example and color matching to the background from some Cow Tutorial footage:
One click later, in the ballpark:
And this, color mismatch between takes (footage from FCP X Training):
A click later the color changes are hardly noticeable:
I think you have to take the tool for what it is. It does color match and sometimes it gets there and sometimes it doesn’t, just like any other “automatic” tool: color balance for example. I just had a bunch of footage that had a horrible blue cast and color balance got me not to a final color correction, but at least to the point where the blue color cast wasn’t a distraction to me while editing.
Regarding the Color Match being “invisible”, I agree. However if it is just an issue of quality because of the image possibly degrading, that shouldn’t be an issue because FCP X renders with “float” precision and filters stacked upon filters don’t result in generation loss.
So when Color Match is working, it is very impressive indeed.
T. Payton
OneCreative, Albuquerque -
Lance Bachelder
January 7, 2012 at 2:00 amWhy not just the good old copy and paste effect like FCP7? Fast and it works. You can also go to your corrected interview and save the color timing as a pre-set in the Color Board naming it whatever you like.
Lance Bachelder
Writer, Editor, Director
Irvine, California -
Thomas Frank
January 8, 2012 at 12:39 amI noticed Color Match does really good job when in both clips have the same type or amount of colors.
Example if one clip has allot white and you color match it with a clip with no whites it will most likely miss it.So I think it was designed for same scene different camera different angle. Do not know…
