Activity › Forums › Creative Community Conversations › Major Import Problem using FCPX + iMAC 2013
  • Major Import Problem using FCPX + iMAC 2013
    Posted by Simon Torkington on November 6, 2013 at 9:05 am
    Hi All,
    A plea for help. I am trying to import C300 footage into FCPX on my brand new iMac (3TB Fusion Drive – 32GB RAM).
    I have tried importing directly from the CF card via a card reader and from backups using Canon XF Utility.
    Whatever I try I get a list detailing dozens of unsupported clips. This is one example of that list:
    6759_screenshot20131105at17.48.17.png.zip
    If I continue with the import all I get is three 30 second duration sections of longer clips (approx 12 minutes).
    I have looked at the folder structure, and everything but the MXF files is failing to import as detailed in the list above. Here’s a picture.
    6762_screenshot20131105at17.55.18.png.zip
    The import folder in FCP X is show in the image below. It seems to lack a lot of the required information.
    6763_screenshot20131106at11.48.57.png.zip
    Now here’s the really weird thing. I can import these files into FCPX on my laptop with no problem. Same version of FCPX, same version of Canon XF Utility and I have matched every setting I can see. Here’s how the import page looks on the laptop. As you can see the information is complete.
    6764_screenshot20131106at11.17.39.png.zip
    I have tried everything I have read online including trashing preferences in FCPX, uninstalling and reinstalling FCPX. Everything I am using is the latest version. I have even updated to OS X Mavericks.
    I have been sitting her for about 15 hours trying to fix this as I am up against a tight deadline on two corporate films. My head is fit to explode.
    Any help from out there would be hugely appreciated.
    Best,
    Simon
    Simon Torkington replied 12 years, 10 months ago 3 Members · 3 Replies
  • Darren Roark
    November 6, 2013 at 7:31 pm
    Did you try a different CF reader? Sometimes they don’t get along.
    Second, can you import your footage with your laptop to an event and then copy the event over to your iMac? I know it doesn’t solve the bigger problem, but it will get you going.
    Normally this goes in this forum: https://forums.creativecow.net/fcpxtechnique
  • Jeremy Garchow
    November 6, 2013 at 7:52 pm
    You have to double lick the encompassing folder so it’s the only directory.
    Not like this:
    But like this:
  • Simon Torkington
    November 6, 2013 at 8:06 pm
    Thank you folks.
    After almost three hours on the phone with Apple support we fixed the problem…but we’re not quite sure how, which is a bit of a worry.
    Simon.
