Activity › Forums › Apple Final Cut Pro Legacy › Major Compressor Issues
Jeremy Garchow
October 29, 2009 at 3:44 pmHow is the RAM physically configured in your Mac? What is where?
You can check this out by going to Apple Menu > About This Mac > More Info
Then click on memory. Take a screen shot of the resulting window and post it here.
Jeremy
Jeremy Garchow
October 29, 2009 at 4:18 pmYep, all good there.
Did you try clearing the cache and history, as well as resetting background processes in Compressor?
Jeremy
Scott Bush
October 29, 2009 at 4:24 pmYes I did… and then I completely reinstalled the OS and everything else, too; just for good measure… There’s something wacky going on here that doesn’t report in diagnostics.
Chris Borjis
October 29, 2009 at 4:24 pmscott download and install the free utility “cache out x”
don’t know if that helps but its worth a try.also repair permissions if you have not already.
Jeremy Garchow
October 29, 2009 at 4:36 pm[Chris Borjis] “scott download and install the free utility “cache out x” “
Which reminds me, (thank you, Chris) that there’s Comressor repair as well:
https://www.digitalrebellion.com/compressor_repair.htm
Jeremy
Scott Bush
October 29, 2009 at 4:51 pmAlready cleaned caches, ran compressor repair, onyx, etc before my clean installation (all of that failing is what led me to do the clean install). But a fresh os install (with no archive and install) would be even cleaner, no?
Jeremy Garchow
October 29, 2009 at 5:03 pm[Scott Bush] “But a fresh os install (with no archive and install) would be even cleaner, no? “
Should be, but I’d run it again just in case.
Scott Bush
October 29, 2009 at 5:23 pmFair enough, I’ll give it a try.
Should ask – is there any downside to using something like compressor repair? I mean, let’s say it works – could I then just run it every day without any ill effects?
