Activity › Forums › Apple Final Cut Pro Legacy › Maintaning file structure when converting to Pro Res
  • Maintaning file structure when converting to Pro Res
    Posted by Daniel Neutzsky-wulff on August 1, 2012 at 1:46 pm
    I just received a hard-drive containing the footage for a music video. They spent some time organizing all of the footage into different folders.
    My question:
    Is it possible to keep the same file structure with all the folders intact after converting to Pro Res?
    I usually run the H.264 files through Batch Export in Final Cut Pro. Is there an easier way of doing it while maintaining the folder structure from the original hard-drive?
    Shane Ross replied 14 years, 2 months ago 4 Members · 8 Replies
  • 8 Replies
  • Joe Barta iv
    August 1, 2012 at 1:59 pm
    Use Compressor, it will put the files right back in the same folder they came from.
    Bars & Tone
    SALUTE!
  • Daniel Neutzsky-wulff
    August 1, 2012 at 2:07 pm
    How do I do that?
  • Joe Barta iv
    August 1, 2012 at 2:18 pm
    Open the Compressor program.
    Drag the files you want to covert from the folder to the DropZone (down arrow) in the batch window.
    In the Settings window of Compressor, choose QuickTime and the version of ProRes you want, drag this to the the clips you put in the batch window.
    Click Submit
    This will convert the files to ProRes and put them back into the same folder. Also, preserving your original files.
    August 1, 2012 at 2:37 pm
    I have a folder structure that looks something like this:
    Project Name
    /Location_1_Day_1
    /Location_1_Day_2
    /Location_2_Day_1
    /Location_1_Day_2
    Etc. etc.
    Do i have to manually drag and drop every file into the compressor batch window? This seems like a very lengthy procedure given that I have 200+ clips to convert.
    I tried dragging the entire folder into the batch window, that doesn’t work. Any other suggestions?
    August 1, 2012 at 2:58 pm
    Compressor can’t seem to handle all of the files at once.
    Just hangs and I have to force quit.
  • Joe Barta iv
    August 1, 2012 at 3:10 pm
    You can Select All the files in a folder then drag the group over to the batch window.
    I don’t know of any file limit in Compressor. Sometimes you have to wait a bit when moving in a bunch of files for the program to Cache everything.
  • Jason Brown
    August 1, 2012 at 3:37 pm
    Compressor seems to hang on conversions of a large number of files (+30)…if u let it sit for 5 min or so it usually does respond and will convert…u just have to be patient. (very patient) haha
    One clever way I found to select multiple files in multiple folders is using the find function.
    If u search the top level folder for all files with .mov or .mp4 or whatever, it will return a result of every file in that “tree”
    It’s a good way to rename files as well.
  • Shane Ross
    August 1, 2012 at 3:53 pm
    Wait wait wait wait.
    Did they organize the TAPELESS media, meaning these are backups of full card structures from tapeless cameras? In the cameras format (AVCHD, H.264)? Or are they converted files?
    Sounds like this is tapeless media, in which case you need to use Log and Transfer to convert this. And organize it inside FCP to match.
    Shane
    Little Frog Post
