Activity › Forums › Compression Techniques › Maintaining metadata with Compressor
  • Maintaining metadata with Compressor
    Posted by Scott Davis on November 21, 2008 at 9:17 pm
    I use compressor a lot for format conversions. We have a lot of metadata attached to the files (inserted in Spotlight comments. Is there a way using Compressor to maintain the metadata from the original file?
    Scott Davis
    View Scott Davis's profile on LinkedIn
    Scott Davis replied 17 years, 9 months ago 2 Members · 2 Replies
  • Andy Mees
    November 22, 2008 at 5:12 am
    Scott
    In the Inspector window’s Actions tab you can set Compressor to run a simple Applescript at the end of each encode job
    Something along the lines of set the comments of fileA to the comments of fileB should do it.
    Cheers
    Andy
  • Scott Davis
    December 16, 2008 at 12:42 am
    Andy, I’ve been overwhelmed with other work and have just got back to this issue. I have done a very rudimentary study of Applescripting and created a script with “set the comments of fileA to the comments of fileB” in the script editor. Created both a script save and save as application. Tried both and nothing. new spotlight comments are not applied.
    Scott Davis
