Activity Forums Apple Final Cut Pro Legacy Maintaining Best quality with DV
  • Maintaining Best quality with DV
    Posted by Ralph Atkinson on July 17, 2009 at 1:11 am
    Hi Everyone,
    I have footage shot in DVCAM and ingested as DV (PAL). I’m wondering is there any benefit to exporting the end results as Pro-Res before taking it into Compressor?
    I would normally export as the current sequence settings but I’m wondering if that adds more DV compression?
    Recently I have found for things that have a lot of fine detail graphics that if I use a Pro-res sequence and create the graphics in Motion using “Broadcast PAL”, then bring the Graphics & DV footage into the Pro-res sequence it looks MUCH cleaner in the end DVD.
    So it got me wondering if the DV export is also degrading the footage slightly or is it because the DV footage is already in the 4:1:1 colour space it doesn’t matter. This is not for Broadcast, only corporate video DVD distribution but I’d like to keep the quality up as far as I can given the DV footage limitation.
    Ralph
    Tony Young replied 17 years, 2 months ago 6 Members · 9 Replies
  • 9 Replies
  • Alex Elkins
    July 17, 2009 at 10:51 am
    [Ralph Atkinson] “I’m wondering is there any benefit to exporting the end results as Pro-Res before taking it into Compressor?”
    Yes, there is. Things like graphics and any colour correction will be visibly cleaner looking. Definitely render as ProRes.
    Best,
    Alex Elkins
  • David Roth weiss
    July 17, 2009 at 1:53 pm
    However, these benefits that Alex points out don’t come with just an export to ProRes, the timeline must be rendered as ProRes first. So, either move everything to ProRes timeline and render, or change the compressor settings in Sequence>>Settings to ProRes and then re-render.
    David Roth Weiss
    Director/Editor
    David Weiss Productions, Inc.
    Los Angeles
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, and Indie Film & Documentary forums.
  • Alex Elkins
    July 17, 2009 at 1:59 pm
    Thanks David, I was quite vague in my response there.
    Set the sequence to ProRes, render, then export using ‘Current Settings’ for optimal quality.
  • David Roth weiss
    July 17, 2009 at 2:17 pm
    That’s okay Alex, cuz I left out the export info…
    Between the two of us we have managed to include everything.
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Juha Vauhkonen
    July 17, 2009 at 2:20 pm
    Hey, is this with Prores compression only, that you should render the timeline as Prores first before exporting? What about Uncompressed formats?
    I don’t understand what’s the point that one has to render the timeline to Prores before exporting, unless you want to check the final quality before export?
    I thought the point of all those dozens of compression settings in the export window was to free FCP user from hassle to create extra timelines for different compressions…?
  • David Roth weiss
    July 17, 2009 at 2:26 pm
    [juha vauhkonen] “Hey, is this with Prores compression only”
    We are talking about DV… DV compression hammers graphics and text because it knock it all down to 4:1:1 color space. Don’t sweat the other video codecs, they are are all 4:2:2 color space and so they won’t destroy graphics the way DV does. Get it?
    David Roth Weiss
    Director/Editor
    Los Angeles
  • Alex Elkins
    July 17, 2009 at 2:35 pm
    [juha vauhkonen] “I thought the point of all those dozens of compression settings in the export window was to free FCP user from hassle to create extra timelines for different compressions…?”
    This is the case as long as you tick ‘Recompress all frames’ in the Export window. Otherwise all you’re doing is essentially exporting a DV movie, then converting the lower quality version to ProRes – rendering in the timeline as ProRes, or re-compressing all frames, strips the low quality render and keeps it in the best quality it can.
    Hope that makes a bit more sense.
    Best,
    Alex Elkins
  • Chris Poisson
    July 17, 2009 at 4:55 pm
    DR,
    You two did miss something, and that is to set your render settings in the video processing tab to high precision YUV and set motion filtering to best.
    Have a wonderful day.
  • Tony Young
    July 19, 2009 at 6:03 pm
    Would you get any better quality if you digitized DVCAM tapes to ProRes in the first place and then put them on a Prores timeline?
    Or would it be the same quality to use the DVCAM footage that has been digitized to DVNTSC and then placed on a Prores timeline?
