Activity › Forums › Compression Techniques › maintaining aspet ratio
  • maintaining aspet ratio
    Posted by Fote Video on June 26, 2008 at 8:57 pm
    Hello,
    I’m trying to batch process 3,000 video clips to a non-standard video size (477×359)via Compressor 3.02. The source clips are all different sizes and shapes. I don’t need them to fill the video space just to conform and maintain their aspect ratio. I’ve done numerous tests, but the videos continue to ‘fit to fill’. I’ve got the resize controls off and my custom output with square pixels. This seems like it should be easy to accomplish, but I’m failing miserably. Thanks in advance.
    Jeffrey
    Fote Video replied 18 years, 3 months ago 2 Members · 4 Replies
  • Daniel Low
    June 26, 2008 at 10:19 pm
    You need to add ‘Padding’ to your source. Look under the Geometry settings in the Inspector.
    P.S. why 477×359? It’s a tricky resolution for a codec to deal with. Why not 480×360 which is a perfect size and it’s spot on 4:3?
    Please post back saying what solved your problem. It could help others, and saying ‘thanks’ is free!
  • Fote Video
    June 27, 2008 at 1:39 pm
    Thanks for pointing out the dimension point. My question with padding is how do I know my amount of padding when my source material varies in size. Do I put it at 4:3 padding? I’ll continue to experiment, thanks for the reply
    Jeffrey
  • Daniel Low
    June 27, 2008 at 2:29 pm
    IIRC just choose ‘4:3’ padding. It should figure how much to add for each file automatically.
  • Fote Video
    June 27, 2008 at 3:03 pm
    Thanks for your time
