Activity Forums Apple Final Cut Pro Legacy maintaining a 4:3 aspect within 16:9FHA project?
  • maintaining a 4:3 aspect within 16:9FHA project?
    Posted by Adam Taylor on August 19, 2006 at 11:52 am
    My problem probably has a fairly easy answer, but i’m still fairly new to FCP and really need to get this cracked asap!!
    I have a project (commercial) that is being cut in 16:9 Anamorphic for output to DigiBeta. I need to incorporate into this project a clip that has been recorded at 4:3. I want to keep this aspect ratio for this clip, and overlay it on a background plate that fills the 16:9 frame. When i try to do this, my 4:3 clip is being stretched to match the 16:9 ratio of the project….which i do not want.
    Any suggestions how this is done. I’ve tried looking in the manual but couldn’t find the answers i need.
    thanks in advance.
    Adam
    “silly keeps you sane”
    Adam Taylor replied 20 years ago 2 Members · 2 Replies
  • Jhaughey
    August 19, 2006 at 1:11 pm
    double click the 4/3 clip in your timeline, navigate to the distort tab, which is within the motion tab in your viewer.
    make this +33.33%. your clip is will now become “pillarboxed” ie. black bars on the edge of your picture. this is the correct aspect ratio for 4/3 within a 16/9 project. you’ll need to zoom into your picture to get rid of the bars. Unfortunatley you will lose information top and bottom of your frame.
    hope that’s what you were after
    Joe Haughey
    http://www.pogofilms.com
  • Adam Taylor
    August 19, 2006 at 1:23 pm
    brilliant!
    thanks Joe, exactly the reply i needed!
    regards
    adam
