Activity Forums Adobe After Effects Expressions Maintain X position of shape relative to rotation of a square
  • Maintain X position of shape relative to rotation of a square
    Posted by Elliot King on March 25, 2022 at 10:57 am
    Hi everyone.
    I have an expression query that I really hope someone can help me with!
    Please see x2 attached screenshots. As you can see, I have a square scaling down and rotating in the centre of my comp. I also have two rectangles either side that are to scale up or move along the X axis while remaining perfectly aligned to opposing corners of the square, even while it rotates.
    I’m pretty sure it’s something to do with Math.cos expression, however I can’t seem to get it right. Any suggestions?
    Thanks in advance.
    Elliot King replied 4 years, 5 months ago 3 Members · 3 Replies
  • Filip Vandueren
    March 25, 2022 at 11:20 am
    Hi Elliot, I think the easiest solution that comes to mind now is take maximum/minimum of the cos of all four corners.
    so, if the radius of the circle those 4 corners fall on is say 200 pixels:
    a = thisComp.layer("square").transform.rotation.value;
    r = 200;
    rightBoundaryX = r * Math.max(
    Math.cos(degreesToRadians(a-45))),
    Math.cos(degreesToRadians(a+45)),
    Math.cos(degreesToRadians(a+135)),
    Math.cos(degreesToRadians(a-135))
    leftBoundaryX = r * Math.min(
    Math.cos(degreesToRadians(a-45)),
    I haven’t tested this code, but I hope it sets you in the right direction
  • Dan Ebberts
    March 25, 2022 at 4:18 pm
    Another possibility would be to use sourceRectAtTime() and toComp() to establish the corners:
    L = thisComp.layer("square");
    r = L.sourceRectAtTime(time,false);
    ul = L.toComp([r.left,r.top]);
    ur = L.toComp([r.left+r.width,r.top]);
    ll = L.toComp([r.left,r.top+r.height]);
    lr = L.toComp([r.left+r.width,r.top+r.height]);
    xMin = Math.min(ul[0],ur[0],ll[0],lr[0]);
    xMax = Math.max(ul[0],ur[0],ll[0],lr[0]);
  • Elliot King
    March 28, 2022 at 5:04 pm
    Thank you both very much. This is extremely helpful.
