Activity Forums Adobe After Effects maintain quality of a composition when scaling down?
  • maintain quality of a composition when scaling down?
    Posted by Eric Staswick on July 23, 2010 at 5:10 pm
    Having trouble understanding this concept in AE.
    I have a main composition which has a composition nested inside it. I have a camera set-up in the main composition to push into the nested composition untill fills the frame (for example the nested comp is a picture on a wall. when you zoom in the picture fills the frame.) So if I do this the composition is scalled down to something like 30%(to fit in the initial camera view,) as the camera zooms in the nested composition becomes pixely (I assume because it’s scaled down.) So, my question is what is the proper way to do this, obviously the quality is there because the ensted comp is 720p ust like the main comp.
    I have tried google but really not sure how to articulate this in a search.
    Charles Taylor replied 16 years, 1 month ago 2 Members · 3 Replies
  • Eric Staswick
    July 23, 2010 at 9:08 pm
    Thanks dave, sounds like perhaps my best bet the is to prerender the comp with 3d movement and then put it in the main comp as a video file?
  • Eric Staswick
    July 23, 2010 at 9:35 pm
    Would there be another way to maintain the sharpness but have it treated as a flat layer?
  • Charles Taylor
    July 26, 2010 at 12:20 am
    Definitely lot’s of good reasons to pre-render, but it shouldn’t look better when you do…
    What exactly is the problem here – is AE detecting that the comp is at 30% res and deciding that a 1/2 res render is “good enough”? If it is, that’s scary. It shouldn’t do that…
    Director of Photography
    http://www.CharlesAngusTaylor.com
