Activity › Forums › Apple Final Cut Pro Legacy › Maintain HDV aspect ratio on export to Comressor H264 LAN….?
  • Maintain HDV aspect ratio on export to Comressor H264 LAN….?
    Posted by Joe Murray on October 29, 2007 at 11:38 pm
    I can’t work out what I’m doing wrong, because I’ve done it 20 times before.
    But I think I’ve always used different work around.
    When exporting my 1080 50i project to Compressor it is coming out streched to full height – ie anamorphic.
    How do I keep it letterboxed in a 4×3 movie?
    and
    What is the simplest method to get the correct aspect ratio on export?
    Lee Berger replied 18 years, 11 months ago 3 Members · 2 Replies
  • Rafael Amador
    October 30, 2007 at 6:25 am
    You want your movie letterboxed, so is a 16×9 on top of a 4×3 screen with two black bands, on top and down. isn’t it?
    To get that you must edit your 16×9 film, and when finished set the 16×9 secuence on top of a 4×3 sequence. There is not other way.
    If you are exporting a movie 16×9 and look wrong when played with QT, do this:
    – Comm-J (properties)> Video track> Visual setting…
    Them uncheck “Preserve Aspect Ratio” and change the “Scaled Size” values as you need it.
    Rafael
  • Lee Berger
    October 30, 2007 at 9:52 am
    You can achieve 3:4 letterbox by using Compressor’s Letterbox Filter
    View your encoding setting in the inspector . Select tab for Filters (4th from the left) and check the letterbox filter. Set Type = Scale, Position = Center, Output = 16 x 9. In the Geometry tab set the Frame size to your desired output size (eg. 640×480, 320×240, etc.) This works for me.
    Lee Berger
    http://www.leebergermedia.com
