Activity › Forums › Adobe After Effects Expressions › Maintain Gap Between Text Layers, No Matter The Width Of Text
  • Maintain Gap Between Text Layers, No Matter The Width Of Text
    Posted by Andrew Ross on January 14, 2022 at 5:25 pm
    Hi guys
    I have a comp with 5 text layers on the X axis.
    I would like these text layers to be positioned 200px apart from each other.
    I’m going to be duplicating this composition numerous times and altering the text using “thisComp.name” but I would like the distance between the layers to remain at 200px no matter how long the word happens to be, whether it’s 3 letters or 20.
    These text layers will be animating along the x-axis from left to right (I’m not sure If this has any bearing on the expression).
    I’ve done some searching on the forums and have found a few expressions that I thought would do the trick, but they always seem to end up with the text overlapping and not keeping the distance between the layers.
    <font face=”inherit”>My knowledge of expressions isn’t that adept to be able to edit them so that’s where I’m probably falling with this one as I imagine it’s a simple task, so apologies if I’m posting something that has already been posted but like </font>I<font face=”inherit”> say, </font>I<font face=”inherit”> can’t get some of the expressions on here to work. </font>
    Thanks in advance
    Andrew
    Filip Vandueren replied 4 years, 6 months ago 4 Members · 4 Replies
  • Kevin Camp
    January 14, 2022 at 7:21 pm
    Something like this should work, add it to the position property and set the ‘target’ to be the layer that you want it to maintain 200px from.
    target = thisComp.layer("LayerToFollow") ;
    rect = target.sourceRectAtTime() ;
    x = target.position[0] + rect.left + rect.width + 200 ;
    [ x, value[1] ]
    The expression assumes that the text layers are left-justified and none are parented.
    If you animate the furthest left text layer, the text layers with that expression will follow it along the x-axis.
  • Andrew Ross
    March 3, 2022 at 10:24 am
    Hi Kevin
    Thanks for getting back with this. It did the job in the end so thank you so much for that 🙂
  • Andy Engelkemier
    March 3, 2022 at 1:05 pm
    Yeah, that parent business what a huge pain in my butt. I realized, after Basically finishing something, that what I had designed would have worked much better with a few child-parent relationships.
    I haven’t come across it yet. Does AE let us do something like: thisLayer == child ? parent info : nonParented value;
    I obviously wouldn’t do that shorthand, but just wanted to get the idea across. I’d Like to create a bunch of code snippets somewhere that I can reuse, and accounting for those things could definitely help, especially if a coworker uses a snippet for something they are working on.
  • Filip Vandueren
    March 4, 2022 at 8:48 am
    Hi Andy, checking that is possible with:
    thisLayer.hasParent
