Activity › Forums › Apple Final Cut Pro Legacy › Maintain audio pitch
  • Maintain audio pitch
    Posted by Steve Freebairn on March 30, 2006 at 8:18 pm
    Is there a really easy way without having to go to Soundtrack, to maintain audio pitch when slowing a clip down. So for instance, if you slow a clip to say 80% so that it goes from 30p to 24P and you want the voices to sound the same.
    Steve Freebairn replied 20 years, 6 months ago 2 Members · 4 Replies
  • Captain Mench
    March 30, 2006 at 8:42 pm
    You could TRY the AU Pitch shift audio filter in FCP… but 20% is a long way to go…
    CaptM
  • Captain Mench
    March 30, 2006 at 8:46 pm
    Just did a test… pitch shift of about 250 is almost what you need for 80% video to sound ‘correct’… AND it wasn’t too bad.
    CaptM
  • Captain Mench
    March 30, 2006 at 8:47 pm
    Make that 400… sorry.
    CaptM
  • Steve Freebairn
    March 30, 2006 at 9:50 pm
    Thanks, I appreciate your help. I normally use Premiere Pro and there is a button that you can check or uncheck if you want to maintain the audio pitch, so I was hoping that Final Cut had a similar or comparable built in feature. Thanks for researching it for me.
