Activity Forums Adobe Premiere Pro mainconcept mpeg plug render preview frame rate problem
  • mainconcept mpeg plug render preview frame rate problem
    Posted by Oscar G. on April 6, 2005 at 5:56 pm
    Hy
    I am trying the demo version of the mainconcept mpeg pro plug.
    The video system of my sequence is PAL and i over check capture settings to do a pal mpeg2 file.
    when i put the mpeg video in the timeline i can read it correctly and when i use a premiere transition i have to render a preview (which it’s normal).
    whem i press enter to render the preview i’ve got his message : “The frame rate output by Premiere (25.00) does not match the selected MPEG frame rate (29,97)”
    i’m capturing mpeg file with an ati all in wonder 8500DV. All mpeg generated with the mpeg pro plug are correct (25 fps- 720/576).
    If i try to capture in dv format (via the mpeg pro interface using the ms codec) no way to create a pal video file!!!i alway have a ntsc file…
    does someone have any ideas to this issue?
    regards
    oscar
    Oscar G. replied 21 years, 5 months ago 1 Member · 0 Replies
  • 0 Replies
