Activity Forums Compression Techniques MainConcept H.264 frame rate issues with Final Cut output
  • MainConcept H.264 frame rate issues with Final Cut output
    Posted by Tony Mugavero on January 26, 2010 at 3:37 pm
    Hello, first time poster hoping the vast knowledge here can point me in the right direction 🙂
    I am using MainConcept Reference to encode a file output from Final Cut using its QuickTime Exporter (It’s a friend’s file). The frame rate on the input file is showing “Variable”, with the lowest fps at .003 and the highest at 29.97 for an overall framerate of 0.978 fps. MediaInfo says the video portion is ~5min but the audio portion says it’s 10sec (which it should be).
    This file plays perfectly in QuickTime, but when I encode it with MainConcept to H.264/AAC, it comes out as a 5min file with the video slowed waaaay down. If I take the file into QuickTime Pro and re-export with the same settings (essentially washing the file I guess), then use that file in MainConcept, it encodes perfectly.
    I have tried all variations in the H.264 codec settings and have been unable to get the frame rate to come out right. Has anyone experienced a similar issue, or know of a way to get MainConcept Reference to handle Variable frame rate inputs?
    Here is the MediaInfo output of the source file from FinalCut (pre MainConcept Reference)
    Format : MPEG-4
    Format profile : QuickTime
    Codec ID : qt
    File size : 32.7 MiB
    Duration : 5mn 15s
    Overall bit rate : 870 Kbps
    Encoded date : UTC 2009-10-07 02:52:37
    Tagged date : UTC 2009-10-07 02:52:39
    Writing library : Apple QuickTime
    Video
    Format : AVC
    Format/Info : Advanced Video Codec
    Format profile : Main@L4.1
    Format settings, CABAC : No
    Format settings, ReFrames : 2 frames
    Codec ID : avc1
    Codec ID/Info : Advanced Video Coding
    Duration : 5mn 15s
    Bit rate mode : Variable
    Bit rate : 820 Kbps
    Width : 1 440 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Original display aspect ratio : 4:3
    Frame rate mode : Variable
    Frame rate : 0.978 fps
    Minimum frame rate : 0.003 fps
    Maximum frame rate : 29.970 fps
    Resolution : 24 bits
    Colorimetry : 4:2:0
    Scan type : Progressive
    Bits/(Pixel*Frame) : 0.539
    Stream size : 30.8 MiB (94%)
    Language : English
    Encoded date : UTC 2009-10-07 02:52:36
    Color primaries : BT.709-5, BT.1361, IEC 61966-2-4, SMPTE RP177
    Transfer characteristics : BT.709-5, BT.1361
    Matrix coefficients : BT.709-5, BT.1361, IEC 61966-2-4 709, SMPTE RP177
    Audio
    Format : PCM
    Format settings, Endianness : Little
    Format settings, Sign : Signed
    Codec ID : sowt
    Duration : 10s 276ms
    Bit rate mode : Constant
    Bit rate : 1 536 Kbps
    Channel(s) : 2 channels
    Sampling rate : 48.0 KHz
    Resolution : 16 bits
    Stream size : 1.88 MiB (6%)
    Language : English
    Daniel Low replied 16 years, 7 months ago 2 Members · 1 Reply
  • Daniel Low
    January 26, 2010 at 11:37 pm
    As you’ve figured out, your source file is screwed up.
    “There’s no chance that the iPhone is going to get any significant market share. No chance.”
    Steve Ballmer To USA Today: 30 April 2007
