Activity Forums Apple Final Cut Pro Main Storyline Has HUGE Gap Between Connected Clips
  • Main Storyline Has HUGE Gap Between Connected Clips
    Posted by Shane Mcgee on January 6, 2012 at 8:28 am
    Anyone experience a massive gap between connected clips and the main timeline? All i did was select/finalize a clip from an audition and the whole thing tweaked out….it seems like a glitch?
    15″ MacBook Pro Quad Core i7 2.0GHz
    1TB G-RAID
    Final Cut Pro X
    Canon T2i
    Oren Hercz replied 14 years, 2 months ago 4 Members · 4 Replies
  • Aaron Rock
    January 6, 2012 at 4:51 pm
    Is there anyplace where these clips overlap other clips below? if not than it’s supposed to drop next to the main storyline.
    Try jumping out of the timeline to the project window and re-entering said project. I find this often works to refresh the location of tracks. As does changing to a different timeline view then switching back. Otherwise trashing your preferences may help. Hopefully one of these three works for you. Good Luck.
  • Shane Mcgee
    January 6, 2012 at 9:09 pm
    yeah tried all that….theres nothing in between them, which is why its weird…its basically just the main storyline with some connected clips above it, but not they are about 30 seconds of scrolling the mouse straight up.
    How do you trash pref in fcpx?
    1TB G-RAID
    Final Cut Pro X
    Canon T2i
  • T. Payton
    January 7, 2012 at 1:05 am
    I’ve actually experienced this once. Seems like a glitch. Just move the clip down, or reconnect it. It will snap back down where it should be.
    T. Payton
    OneCreative, Albuquerque
  • Oren Hercz
    July 19, 2012 at 6:08 pm
    Hi, did you ever figure this out? I am having the same problem. Trashing preferences didn’t do anything for me.
    Cheers,
    Oren
