Activity › Forums › Adobe Premiere Pro › Main Concept DV Codec
Posted by John Frey – digital west video productions on May 17, 2005 at 5:32 amI do not see the Main Concept DV codec listed as an option when rendering a movie in P.Pro 1.5, only the Microsoft DV codec. I have purchased and downloaded the Main Concept DV codec. How do I install it into P.Pro 1.5?
Mike Velte replied 21 years, 3 months ago 4 Members · 9 Replies -
Steven L. gotz
May 17, 2005 at 5:35 amIt was there before you bought it. You didn’t need to pay a penney for it. The standard DV AVI export uses the MainConcept codec.
Steven
Adobe Premiere Pro 1.5 / After Effects 6.5 Pro https://www.stevengotz.com
Learning Adobe Premiere Pro 1.5 https://www.lynda.com
Contributing Writer, PeachPit Press, Visual QuickPro Guide, Premiere Pro 1.5 -
Mike Velte
May 17, 2005 at 11:26 amThe Main Concept codec is available;
File>Export>Movie>Settings>General>File Type= Microsoft AVI (not DV).
Then Click Video and change the compressor to the Main Concept DV Codec 2.4.11Steve;
My understanding is that Pro’s native MC codec use is for the creation of Preview files only. Exporting a DV.avi uses Microsoft DirecrShow codec.
I have also done testing that shows a marked difference after 3 generations between both export options. -
May 17, 2005 at 2:29 pmMike,
How do I get the latest Main Concept 2.4.16 DV Codec update into P. Pro to replace 2.4.11?
Steven L. gotz
May 17, 2005 at 3:18 pmHmmm. Are you sure? I know that the MainConcept codec is used in Premiere Pro 1.5 as the default codec for editing. And it is not showing up as a special choice under Microsoft AVI. I understand that you have to pay for other MainConcept codecs, or upgrade, or whatever, but I was operating under the assumption that MainConcept is what the progeam uses for DV AVI.
Steven
Mike Velte
May 17, 2005 at 9:00 pmJohn,
Just install the latest version, it will update Window’s Device Manager which is where all apps access codecs.Steve,
I am never sure about anything, but if I was a bettin guy, I would give you 3;2 odds I am right. Pro uses the codec internally only. There is no mention of it for any export options unless the paid for version is installed.. -
Lloyd Coleman
May 18, 2005 at 5:55 pmI just talked to Mark at MainConcept and he said that when you export using Microsoft DV AVI it does use the MainConcept encoder, even though there is not a place to specificially select MainConcept and the name still says Microsoft DV AVI.
Steven L. gotz
May 18, 2005 at 6:44 pmWhew! I thought so. But arguing with Mike Velte can be an extremely precatious place to be. 🙂
Now that we know the answer, I can say that the reason I thought so was because of the speed of AVI exports after a render has already been done. I didn’t think there was enough time to change codecs. But I could not find proof. My codec checker was so confused it thought it was a Sony codec. I need a new checker I guess.
Steven
Steven L. gotz
May 18, 2005 at 6:48 pmPrecarious even! Darn lack of spell checkers. Caint hardli get nuthin rit no mor.
Steven
