Activity Forums Adobe After Effects Magnification changes when editing mask points
  • Magnification changes when editing mask points
    Posted by Eric Kuehnapfel on September 4, 2009 at 1:55 pm
    I checked this forum the best I could to see if someone posted something similar. Does this happen to anyone? Your zoomed in 200% or 400% and fine-tuning masking points when suddenly the magnification ratio jumps around to another level, sometimes back to 100% or 50% or forward to 800%. I use a Kensington Turbo Mouse with a right button set to drag and I’m not sure if I’m accidentally hitting a hidden function or short-cut while editing the bezier handles. It’s extremely annoying and driving me crazy. Any insight would be very appreciated. Thanks!
    Regards, Eric.
    Eric Kuehnapfel replied 17 years ago 2 Members · 2 Replies
  • Todd Kopriva
    September 4, 2009 at 3:01 pm
    Maybe you’re accidentally hitting your scroll wheel.
    putting the ‘T’ back in ‘RTFM’ : After Effects Help on the Web
    If a page of After Effects Help answers your question, please consider rating it. If you have a tip, technique, or link to share—or if there is something that you’d like to see added or improved—please leave a comment.
  • Eric Kuehnapfel
    September 4, 2009 at 3:19 pm
    Sometimes there’s a fine line between ignorance and stupidity. The Kensington Turbo Mouse has a scroll wheel hugging the base of the trackball which I never use and which changes the magnification level with the lightest of touches! I have since disabled it in the preferences and all is well again. Thanks Todd.
    Regards, Eric.
